I am creating a building using polygon entity. I want to make it
transparent by rangebar movement. How to pass the callback value to ‘alpha’ in
material section ?
html :-
jsfile :- function getTransValue()
transperency =
document.getElementById(“trans_bld”).value;
return
parseFloat(transperency );
buildings = cesiumViewer.entities.add({
polygon: {
hierarchy: Cesium.Cartesian3.fromDegreesArray(arr),
extrudedHeight: a,
height: b,
material: new Cesium.Color.fromCssColorString©.withAlpha(0.1),
outline: true,
outlineColor: Cesium.Color.BLACK,
outlineWidth: 2,
Here I am using color picker while adding the color.
omar
January 4, 2019, 12:51pm
#2
Notice that material has a type of MaterialProperty, which is different from most others which just have a type of Property:
https://cesiumjs.org/Cesium/Build/Documentation/PolygonGraphics.html?classFilter=PolygonG
So you’ll need to wrap your callback property in one of these types:
https://cesiumjs.org/Cesium/Build/Documentation/MaterialProperty.html
So here’s one way to do that:
var colorProperty = new Cesium.ColorMaterialProperty();
``var color = new Cesium.Color(1, 0, 0, 1);
``colorProperty.color = new Cesium.CallbackProperty(function(time, result){
// You can change the alpha/red/green/blue components dynamically here.
// color.alpha = SomeValue;
return color;
}, false);
And when you’re creating your polygon entity the color material property is what you’d pass:
material: colorProperty
Let me know if that works for you.
