Can I limit the loading area? Not to load a entire globe?
When using a tile service that only provides Korean zones, errors continue to occur because cesiumjs was trying to read the map service of the entire globe.
An error occurred in “gv”: Failed to obtain image tile X: 32 Y: 1 Level: 6.
We tried to limit the map using the example below, but it still seems to load and cut the entire glove.
Is there a way to limit the area of a country without loading the entire globe?
What kind of tile service do you use?
if WebMapTileServiceImageryProvider, you can limit by specifying the rectangle property of the provider.
see this.
https://cesium.com/learn/cesiumjs/ref-doc/WebMapTileServiceImageryProvider.html#.ConstructorOptions
