I create a animation model via ‘scene.primitives.add()’, and I add the model to the ‘viewer.entities’ . Now I can receive position data
in real time. I want to move the animation model when receiving the position data.
(1) create animation model( using the cesium animation demo)
var scene = viewer.scene
var position = new Cesium.Cartesian3.fromDegrees(long, lat) // the position will update in real time
var hpRoll = new Cesium.HeadingPitchRoll()
var fixedFrameTransform = Cesium.Transforms.localFrameToFixedFrameGenerator(‘north’, ‘west’)
var manPrimitive = scene.primitives.add(Cesium.Model.fromGltf({
url: ‘/model/Cesium_Man.gltf’,
modelMatrix: Cesium.Transforms.headingPitchRollToFixedFrame(position, hpRoll, Cesium.Ellipsoid.WGS84, fixedFrameTransform),
minimumPixelSize: 128
manPrimitive.readyPromise.then(function (model) {
// Play and loop all animations at half-speed
model.activeAnimations.addAll({
speedup: 0.5,
loop: Cesium.ModelAnimationLoop.REPEAT
(2) add to the viewer.entities
let manEntity = viewer.entities.add(new Cesium.Entity({
model: manPrimitive,
position: position,
properties: attributes
this is the animation model , I want to move the model to new position when receiving new position data. I need to use it in a real system.
cesium version: cesium 1.37
operating system: win 10
browser: latest chrome
