Cannot access to the Cesium ion
Cannot access to the cesium ion portal. I think it is server down.
Thanks
same here
also here
LogCesiumEditor: Error: Failed to obtain ion server application data: Received response code 504
LogCesiumEditor: Error: Error connecting: Failed to obtain _appData, can’t create connection
this is my problem :anxious_face_with_sweat:
same here. (index):1 Access to XMLHttpRequest at ‘https://api.cesium.com/v1/assets/1/endpoint?
from origin ‘http://localhost:5173’ has been blocked by CORS policy: Response to preflight request doesn’t pass access control check: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
Thank you for reporting this issue. We are aware of it and currently looking into it. The root cause of the issue is caused by the AWS outage currently happening in us-east-1 region. You can read more about the status of AWS here: Service health - Oct 20, 2025 | AWS Health Dashboard | Global
We’ll update you as soon as Cesium ion is back and running.
Ankit
