When I tried to access this case: Cesium Stories.
I got an error like this:
Hi, sorry you are having trouble with the story.
- What browser and operating system are you using?
- What country are you trying to access the story from? (You can message support@cesium.com and reference this issue if you don’t want to post publicly)
- Are you able to view the browser console and see if there are any errors?
My browser is: Google Chrome 118.0.5993.71 (Official Build) (64-bit).
My OS is: Windows 11 Version 22H2 (Build 22621.2428).
I’m trying to access from China.
And the Error Messages from browser console is below:
Cesium.js:81 [Cesium WebGL] Vertex shader compile log: ERROR: 0:48: 'w' : vector field selection out of range
index.js:1561 Vertex shader failed to compile. Compile log: ERROR: 0:48: 'w' : vector field selection out of range
[Cesium WebGL] Vertex shader source:
#version 300 es
#define HAS_NORMALS
#define HAS_TANGENTS
#define HAS_TEXCOORD_0
#define HAS_BITANGENTS
#define LOG_DEPTH
#define OES_texture_float_linear
#line 0
uniform vec2 czm_currentFrustum;
uniform mat4 czm_inverseProjection;
#ifdef LOG_DEPTH
out float v_depthFromNearPlusOne;
#ifdef SHADOW_MAP
out vec3 v_logPositionEC;
#endif
#endif
vec4 czm_updatePositionDepth(vec4 coords) {
#if defined(LOG_DEPTH)
#ifdef SHADOW_MAP
vec3 logPositionEC = (czm_inverseProjection * coords).xyz;
v_logPositionEC = logPositionEC;
#endif
coords.z = clamp(coords.z / coords.w, -1.0, 1.0) * coords.w;
#endif
return coords;
void czm_vertexLogDepth()
#ifdef LOG_DEPTH
v_depthFromNearPlusOne = (gl_Position.w - czm_currentFrustum.x) + 1.0;
gl_Position = czm_updatePositionDepth(gl_Position);
#endif
void czm_vertexLogDepth(vec4 clipCoords)
#ifdef LOG_DEPTH
v_depthFromNearPlusOne = (clipCoords.w - czm_currentFrustum.x) + 1.0;
czm_updatePositionDepth(clipCoords);
#endif
uniform mat3 czm_normal;
uniform mat4 czm_modelView;
uniform mat3 czm_normal3D;
uniform mat4 czm_modelView3D;
struct czm_modelVertexOutput {
vec3 positionMC;
float pointSize;
uniform mat4 czm_model;
uniform mat4 czm_projection;
#line 0
in vec3 a_positionMC;
in vec3 a_normalMC;
in vec3 a_tangentMC;
in vec2 a_texCoord_0;
in vec3 a_bitangent;
out vec3 v_positionWC;
out vec3 v_positionEC;
out vec3 v_normalEC;
out vec3 v_positionMC;
out vec3 v_tangentEC;
out vec2 v_texCoord_0;
out vec3 v_bitangent;
out vec3 v_bitangentEC;
struct ProcessedAttributes
vec3 normalMC;
vec3 positionMC;
vec3 tangentMC;
float tangentSignMC;
vec2 texCoord_0;
vec3 bitangent;
vec3 bitangentMC;
struct SelectedFeature
float _empty;
struct FeatureIds
float _empty;
struct Metadata
float _empty;
struct MetadataClass
float _empty;
struct MetadataStatistics
float _empty;
void initializeAttributes(out ProcessedAttributes attributes)
attributes.normalMC = a_normalMC;
attributes.positionMC = a_positionMC;
attributes.tangentMC = a_tangentMC.xyz;
attributes.tangentSignMC = a_tangentMC.w;
attributes.texCoord_0 = a_texCoord_0;
attributes.bitangent = a_bitangent;
void setDynamicVaryings(inout ProcessedAttributes attributes)
v_texCoord_0 = attributes.texCoord_0;
v_bitangent = attributes.bitangent;
void initializeFeatureIds(out FeatureIds featureIds, ProcessedAttributes attributes)
void initializeFeatureIdAliases(inout FeatureIds featureIds)
void setFeatureIdVaryings()
void initializeMetadata(out Metadata metadata, out MetadataClass metadataClass, out MetadataStatistics metadataStatistics, ProcessedAttributes attributes)
void setMetadataVaryings()
vec4 geometryStage(inout ProcessedAttributes attributes, mat4 modelView, mat3 normal)
vec4 computedPosition;
vec3 positionMC = attributes.positionMC;
v_positionMC = positionMC;
v_positionEC = (modelView * vec4(positionMC, 1.0)).xyz;
#if defined(USE_2D_POSITIONS) || defined(USE_2D_INSTANCING)
vec3 position2D = attributes.position2D;
vec3 positionEC = (u_modelView2D * vec4(position2D, 1.0)).xyz;
computedPosition = czm_projection * vec4(positionEC, 1.0);
#else
computedPosition = czm_projection * vec4(v_positionEC, 1.0);
#endif
#if defined(COMPUTE_POSITION_WC_CUSTOM_SHADER) || defined(COMPUTE_POSITION_WC_STYLE)
v_positionWC = (czm_model * vec4(positionMC, 1.0)).xyz;
#endif
#ifdef HAS_NORMALS
v_normalEC = normalize(normal * attributes.normalMC);
#endif
#ifdef HAS_TANGENTS
v_tangentEC = normalize(normal * attributes.tangentMC);
#endif
#ifdef HAS_BITANGENTS
v_bitangentEC = normalize(normal * attributes.bitangentMC);
#endif
setDynamicVaryings(attributes);
return computedPosition;
void featureIdStage(out FeatureIds featureIds, ProcessedAttributes attributes)
initializeFeatureIds(featureIds, attributes);
initializeFeatureIdAliases(featureIds);
setFeatureIdVaryings();
void metadataStage(
initializeMetadata(metadata, metadataClass, metadataStatistics, attributes);
setMetadataVaryings();
czm_modelVertexOutput defaultVertexOutput(vec3 positionMC) {
czm_modelVertexOutput vsOutput;
vsOutput.positionMC = positionMC;
vsOutput.pointSize = 1.0;
return vsOutput;
void czm_log_depth_main()
ProcessedAttributes attributes;
initializeAttributes(attributes);
#ifdef USE_DEQUANTIZATION
dequantizationStage(attributes);
#endif
#ifdef HAS_MORPH_TARGETS
morphTargetsStage(attributes);
#endif
#ifdef HAS_SKINNING
skinningStage(attributes);
#endif
#ifdef HAS_PRIMITIVE_OUTLINE
primitiveOutlineStage();
#endif
attributes.bitangentMC = normalize(cross(attributes.normalMC, attributes.tangentMC) * attributes.tangentSignMC);
#endif
FeatureIds featureIds;
featureIdStage(featureIds, attributes);
#ifdef HAS_SELECTED_FEATURE_ID
SelectedFeature feature;
selectedFeatureIdStage(feature, featureIds);
cpuStylingStage(attributes.positionMC, feature);
#endif
mat4 modelView = czm_modelView3D;
mat3 normal = czm_normal3D;
#else
mat4 modelView = czm_modelView;
mat3 normal = czm_normal;
#endif
#ifdef HAS_INSTANCING
#ifdef USE_LEGACY_INSTANCING
mat4 instanceModelView;
mat3 instanceModelViewInverseTranspose;
legacyInstancingStage(attributes, instanceModelView, instanceModelViewInverseTranspose);
modelView = instanceModelView;
normal = instanceModelViewInverseTranspose;
#else
instancingStage(attributes);
#endif
#ifdef USE_PICKING
v_pickColor = a_pickColor;
#endif
#endif
Metadata metadata;
MetadataClass metadataClass;
MetadataStatistics metadataStatistics;
metadataStage(metadata, metadataClass, metadataStatistics, attributes);
#ifdef HAS_CUSTOM_VERTEX_SHADER
czm_modelVertexOutput vsOutput = defaultVertexOutput(attributes.positionMC);
customShaderStage(vsOutput, attributes, featureIds, metadata, metadataClass, metadataStatistics);
#endif
vec4 positionClip = geometryStage(attributes, modelView, normal);
#ifdef HAS_SILHOUETTE
silhouetteStage(attributes, positionClip);
#endif
#ifdef HAS_POINT_CLOUD_SHOW_STYLE
float show = pointCloudShowStylingStage(attributes, metadata);
#else
float show = 1.0;
#endif
#ifdef HAS_POINT_CLOUD_BACK_FACE_CULLING
show *= pointCloudBackFaceCullingStage();
#endif
#ifdef HAS_POINT_CLOUD_COLOR_STYLE
v_pointCloudColor = pointCloudColorStylingStage(attributes, metadata);
#endif
#ifdef PRIMITIVE_TYPE_POINTS
gl_PointSize = vsOutput.pointSize;
#elif defined(HAS_POINT_CLOUD_POINT_SIZE_STYLE) || defined(HAS_POINT_CLOUD_ATTENUATION)
gl_PointSize = pointCloudPointSizeStylingStage(attributes, metadata);
#else
gl_PointSize = 1.0;
#endif
gl_PointSize *= show;
#endif
gl_Position = show * positionClip;
#line 0
void main()
czm_log_depth_main();
czm_vertexLogDepth();
gIe @ Cesium.js:81
Sorry, I didn’t describe the problem clearly. I got this error when I clieck the “1/5 Next”(from 1/5 to 2/5) button in the left bottom corner.
Thank you for providing that additional information. I was able to reproduce the error you reported. I have created an issue for the team to investigate the error and update the story with a fix.
