Capturing individual 3D objects from b3dm file
I have a batched 3D model in b3dm format containing 3D tiles (an example is attached) and I’m looking for tools that can help to get the geometry data of each individual object. I need this geometry data to calculate the volume of these individual objects.
I would like to ask you:
  • if it is possible to capture the geometry data of each 3D object.
  • If there is a tool/library/framework that helps to extract these geometries.
I’ve already done a lot of research to find a tool that can help, but couldn’t find one.
I would be very grateful for your help.
Thanks in advance
batched.zip (4.7 KB)
there are many similar tools that can help you to get the data transfer into individual object. but most of these are in Chinese version, i am not sure do you still need these tools. if yes you can send a email to chatonly@126.com and i will send you these tools once i read it.
