Cartographic polygon not clipping correctly
Hi, my cartographic polygon is only clipping whole tiles when it should be slicing them based on the shape of the spline:
Hi @bigwords,
Are you using a custom material? The clipping is performed by the material, so if you use a custom one you must make sure it includes a Material Layer to do the clipping.
Kevin
Oh, I see. Turns out it was only because I was in the lighting only viewport mode. But thanks anyway, I’ll keep that in mind.
