Currently I use Cesium 1.29 and I got a key from BINGMAPS. But when I put “geocoder” to “True”, there is a message showing that I use a default key as follows:
This application is using Cesium’s default Bing Maps key.
Please create a new key for the application as soon as possible and prior to deployment
By visiting https://www.bingmapsportal.com/, and provide your key to Cesium by setting the Cesium.BingMapsApi.defaultKey
Property before constructing the CesiumWidget or any other object that uses the Bing Maps API.
While I put “False”, this message does not appear.
Here is my code for displaying Cesium:
var viewer = new Cesium.Viewer(“idt”, {
timeline: true,
animation: false,
homeButton: false,
screenModePicker: false,
navigationHelpButton: false,
baseLayerPicker: false,
geocoder: true,//false
sceneMode: Cesium.SceneMode.SCENE3D,
imageryProvider: new Cesium.BingMapsImageryProvider({
url: ‘https://dev.virtualearth.net’,
mapStyle: Cesium.BingMapsStyle.AERIAL_WITH_LABELS,
key: myKey
Thank you for your reply
