I set the key inside the BingMapsApi.js file but the globe still didn't appear. I also put the line "BingMapApi.defaultKey = 'Mykey' before the var viewer = new Cesium.Viewer('cesiumContainer') line without success.
Try this:
Cesium.BingMapApi.defaultKey = ‘’;
Hannah
That should be:
Cesium.BingMapsApi.defaultKey = ‘’;
(Maps not Map)
Hi Kevin,
My key as shown above, I tried, in “Hello World.html” having the code as below but did not work. But the same key work for CesiumViewer.
function startup(Cesium) {
‘use strict’;
//Sandcastle_Begin
Cesium.BingMapsApi.defaultKey =’--------’;
//Sandcastle_End
Sandcastle.finishedLoading();
if (typeof Cesium !== “undefined”) {
startup(Cesium);
} else if (typeof require === “function”) {
require([“Cesium”], startup);
Any idea why ?
Thanks
Cheers
TS
Hi TS,
The code you posted works just fine in Sandcastle for me. Here’s the example with our current bing key. Double check your key.
Hope that helps,
- Rachel
Hi Rachel,
Thanks!
Working now.
Cheers
TS
