I have developed a desktop application using Electron framework which uses CesiumJs. From the new cesiumjs(v1.47) version release,Application is started crashing and showing below error.
'An error occurred while rendering. Rendering has stopped.
Error: No url
Error: No url'
I have tested cesiumjs without electron,its working as expected,But If I add the same codebase to the electron framework It's not working.I have followed the below example for testing the cesiumjs with electron.
‘https://cesium.com/blog/2016/04/04/an-introduction-to-cesium-desktop-apps-with-electron/’.
index.html:
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
<title>My Cesium App</title>
<script src="./node_modules/cesium/Build/Cesium/Cesium.js"></script>
<style>
@import url(./node_modules/cesium/Build/Cesium/Widgets/widgets.css);
html, body, #cesiumContainer {
height: 100%; margin: 0; padding: 0; overflow: hidden;
</style>
</head>
<body>
<div id="cesiumContainer"></div>
<script>
</script>
</body>
</html>
main.js:
var app = require('app'); // Module to control application life.
var BrowserWindow = require('browser-window'); // Module to create native browser window.
// Keep a global reference of the window object. If you don't, the window will
// be closed automatically when the JavaScript object is garbage collected.
var mainWindow = null;
// This method will be called when Electron has finished
// initialization and is ready to create browser windows.
app.on('ready', function() {
// Create the browser window
mainWindow = new BrowserWindow({width: 900, height: 600});
// and load the index.html of the app.
mainWindow.loadURL('file://' + __dirname + '/index.html');
// Returned when the window is closed.
mainWindow.on('closed', function() {
// Dereference the window object. Usually you would store windows
// in an array if your app supports multi windows. This is the time
// when you should delete the corresponding element.
mainWindow = null;
// On a PC, the app will quit when we close all windows.
// On a Mac, applications must be explicitly closed.
app.on('window-all-closed', function() {
if (process.platform != 'darwin') {
app.quit();
If I replace cesium node module to old cesium It's started working.
Let me know,If I have to modify/add anything else to the codebase in new cesium version.
Looking for help
Regards,
Darshan
