If the STK Engine from STK Desktop 10.0.1 provides the desired functionality for a simple application, can code be written to make use of the STK Engine API to integrate with Cesium?
Or are one or more STK Components required to integrate with Cesium?
We’re working on the ability to output CZML from STK to Cesium as well as a new Components for easily building web-services meant to be ingested by Cesium clients. Depending on your exact needs, we can make some recommendations for you. Rather than using this list, it’s probably better for you to contact your AGI salesperson for more details. Otherwise, you can email me personally and I’ll try and get things started for you.
