Hi. I think I am facing the same challenge, trying to integrate Cesium with webpack using the tutorial on the Cesium website.
After doing every step according to the tutorial, when I finally run the “npm start” command, I face the following error:
> 0 info it worked if it ends with ok
> 1 verbose cli [
> 1 verbose cli 'C:\\Program Files\\nodejs\\node.exe',
> 1 verbose cli 'C:\\Users\\user\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
> 1 verbose cli 'start'
> 1 verbose cli ]
> 2 info using npm@6.14.9
> 3 info using node@v12.18.3
> 4 verbose run-script [ 'prestart', 'start', 'poststart' ]
> 5 info lifecycle example02@1.0.0~prestart: example02@1.0.0
> 6 info lifecycle example02@1.0.0~start: example02@1.0.0
> 7 verbose lifecycle example02@1.0.0~start: unsafe-perm in lifecycle true
> 8 verbose lifecycle example02@1.0.0~start: PATH: C:\Users\user\AppData\Roaming\npm\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;C:\Users\user\Desktop\internship\neo\cesium-webpack-app\example02\node_modules\.bin;C:\Program Files\Common Files\Oracle\Java\javapath;C:\Program Files\Python38\Scripts\;C:\Program Files\Python38\;C:\Windows\System32;C:\Program Files\nodejs\;C:\ProgramData\chocolatey\bin;C:\Program Files\Git\cmd;C:\Users\user\Anaconda3\Scripts;C:\Users\user\Anaconda3;"C:\Users\user\Anaconda3\Library\bin;";"C:\Users\user\Anaconda3\Library\user\bin;";"C:\Users\user\Anaconda3\Library\mingw-w64\bin;";C:\Program Files (x86)\Yarn\bin\;C:\Program Files\MongoDB\Server\4.4\bin;C:\Program Files\MongoDB\Tools\100\bin;C:\Program Files\PostgreSQL\9.6\bin\psql.exe;C:\Program Files\PostgreSQL\9.6\bin;C:\Program Files\PostgreSQL\9.6\lib;C:\Program Files\PostgreSQL\13\bin;C:\Program Files\PostgreSQL\13\lib;C:\Program Files (x86)\Calibre2\;C:\ProgramData\Anaconda3\Library\bin\graphviz;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files\GDAL;C:\Program Files\GDAL\gdal-data;C:\ProgramData\Anaconda3\Library\bin\graphviz;C:\ProgramData\Anaconda3\Library\bin\graphviz;C:\ProgramData\Anaconda3\Library\bin\graphviz;C:\ProgramData\Anaconda3\Library\bin\graphviz;C:\Users\user\AppData\Local\Microsoft\WindowsApps;C:\Users\user\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\user\AppData\Roaming\npm;C:\Users\user\AppData\Local\Yarn\bin
> 9 verbose lifecycle example02@1.0.0~start: CWD: C:\Users\user\Desktop\internship\neo\cesium-webpack-app\example02
> 10 silly lifecycle example02@1.0.0~start: Args: [ '/d /s /c', 'webpack serve' ]
> 11 silly lifecycle example02@1.0.0~start: Returned: code: 2 signal: null
> 12 info lifecycle example02@1.0.0~start: Failed to exec start script
> 13 verbose stack Error: example02@1.0.0 start: `webpack serve`
> 13 verbose stack Exit status 2
> 13 verbose stack at EventEmitter.<anonymous> (C:\Users\user\AppData\Roaming\npm\node_modules\npm\node_modules\npm-lifecycle\index.js:332:16)
> 13 verbose stack at EventEmitter.emit (events.js:315:20)
> 13 verbose stack at ChildProcess.<anonymous> (C:\Users\user\AppData\Roaming\npm\node_modules\npm\node_modules\npm-lifecycle\lib\spawn.js:55:14)
> 13 verbose stack at ChildProcess.emit (events.js:315:20)
> 13 verbose stack at maybeClose (internal/child_process.js:1021:16)
> 13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
> 14 verbose pkgid example02@1.0.0
> 15 verbose cwd C:\Users\user\Desktop\internship\neo\cesium-webpack-app\example02
> 16 verbose Windows_NT 10.0.18363
> 17 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\user\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "start"
> 18 verbose node v12.18.3
> 19 verbose npm v6.14.9
> 20 error code ELIFECYCLE
> 21 error errno 2
> 22 error example02@1.0.0 start: `webpack serve`
> 22 error Exit status 2
> 23 error Failed at the example02@1.0.0 start script.
> 23 error This is probably not a problem with npm. There is likely additional logging output above.
> 24 verbose exit [ 2, true ]
I’ve tried several solutions that I found online, but nothing worked. Here is my webpack.config.js file:
> const path = require('path');
> const CopywebpackPlugin = require('copy-webpack-plugin');
> // The path to the CesiumJS source code
> const cesiumSource = 'node_modules/cesium/Source';
> const cesiumWorkers = '../Build/Cesium/Workers';
> const webpack = require('webpack');
> const HtmlWebpackPlugin = require('html-webpack-plugin');
> module.exports = {
> mode: 'development',
> context: __dirname,
> entry: {
> app: './src/index.js'
> resolve: {
> alias: {
> // CesiumJS module name
> cesium: path.resolve(__dirname, cesiumSource)
> output: {
> filename: '[name].js',
> path: path.resolve(__dirname, 'dist'),
> // Needed to compile multiline strings in Cesium
> sourcePrefix: ''
> amd: {
> // Enable webpack-friendly use of require in Cesium
> toUrlUndefined: true
> node: {
> // Resolve node module use of fs
> fs: 'empty'
> module: {
> rules: [{
> test: /\.css$/,
> use: [ 'style-loader', 'css-loader' ]
> test: /\.(png|gif|jpg|jpeg|svg|xml|json)$/,
> use: [ 'url-loader' ]
> plugins: [
> new HtmlWebpackPlugin({
> template: 'src/index.html'
> // Copy Cesium Assets, Widgets, and Workers to a static directory
> new CopywebpackPlugin({
> patterns: [
> { from: path.join(cesiumSource, cesiumWorkers), to: 'Workers' },
> { from: path.join(cesiumSource, 'Assets'), to: 'Assets' },
> { from: path.join(cesiumSource, 'Widgets'), to: 'Widgets' }
> new webpack.DefinePlugin({
> // Define relative base path in cesium for loading assets
> CESIUM_BASE_URL: JSON.stringify('')
> // development server options
> devServer: {
> contentBase: path.join(__dirname, "dist")
I am thinking it might be a problem with the configuration in webpack-dev.
Does anyone have an idea about this?
Thank you in advance
