Hello, we need to get “3d buildings ID” and “Height” somehow from Cesium API.
can someone help?
can someone help?
Hi @maxtorgr,
Thank you for reaching out to the community! Are you looking to query the OSM buildings dataset? If so, I recommend that you check out the following styling guide:
-Sam
No , i mean the buildings you already have in Cesium
https://www1.nyc.gov/site/doitt/initiatives/3d-building.page
I want the API get for the metadata from cesium. is that possible?
Hi @maxtorgr ,
You can easily get the all features properties just using below code
var handlerA = new Cesium.ScreenSpaceEventHandler(viewer.scene.canvas);
handlerA.setInputAction(function(click) {
var pickedObject = scene.pick(click.position);
if (Cesium.defined(pickedObject)) {
let totalFeatures = pickedObject.getPropertyNames();
console.log(pickedObject.getProperty(“id”)); // you can get any feature property id, name, height etc.
we need 3d buildings metadata from cesium rest api get Ion REST API documentation – Cesium
Hi @maxtorgr
The data is derived / calculated from the source CityGML data for the New York buildings and stored in the 3D Tileset’s metadata (not exactly a database). The metadata in 3D Tileset is associated with the geometry of the buildings.
I think it would be be tremendously helpful to know a little bit more about your use case to help give you a more specific answer to help you find a solution.
Shehzan
Is anything here useful?
https://vcities.umsl,edu/Examples.html ?
Jerrold
