My problem is that I want to implement a custom timeline that would allow the user to “shrink” it in real time and visualize a “slice” of the data
currently loaded in Cesium + Torque. I will upload a gif to give you an example of what I have and what I aim to achieve.
Here’s a gif of what I have right now, the TorqueImageryProvider successfully feeding the data into Cesium, and I can use the timeline to go back and forth and the data will reflect that accordingly
And here’s is what I am looking to accomplish. Basically, I want Cesium to display the data between the start and end dates represented by the left and right needles on that custom timeline.
I already have the logic to generate a query to the backend when a mouse down event happens in that timeline (when you drag and drop one of the two needles in the timeline), this will generate a query, save it on torque’s state, make a request for the tile metadata to the backend and return it to the frontend.
I hope this make sense. Let me know if you want to know more details.
Cesium 1.37. OSx, testing with Chrome at the moment.
