There are multiple problems with your code.
You are using double quotes inside of your string which is also defined with double quotes.
You aren’t properly escaping new lines
You are using CzmlDataSource instead of KmlDataSource
KmlDataSource doesn’t take a string, only a url or parsed Document.
Here’s what the working code looks like:
var testkml=’<?xml version="1.0" encoding="UTF-8"?>\
New point\
This is a new point.\
135.2, 35.4, 0.\
var parser = new DOMParser();
viewer.dataSources.add(Cesium.KmlDataSource.load(parser.parseFromString(testkml, “text/xml”)));
