I've recently been testing rendering 5000 ellipse entities on the 3d globe. I set each ellipse entity's image that shows a green Arrow that points north.Then I set its strotation value to show where the arrow is pointing.
From observation, almost all ellipses' image appears alright and accurate to its rotation. However, I spotted some with distorted images where the arrow head somehow fuses with another arrow head from opposite direction.
I ventured to a thread- https://groups.google.com/forum/#!topic/cesium-dev/UF9wQugwRf0 , that seems to be similar in coding code but it didn't solve the problem i'm having. The only difference in the code is I'm using image URL path, not canvas.
Using Cesium 1.20
Win 7 Pro
Chrome
Thanks and Regards
Cal
hannah
April 13, 2016, 2:15pm
2
Hello Cal,
I don’t quite understand what you’re seeing. Can you paste a code sample or a screenshot?
Hannah
Hi Hannah,
This is the code sample I've tested.
var entity = viewer.entities.getOrCreateEntity("test");
var ellipseGraphics = new Cesium.EllipseGraphics({
semiMajorAxis: 5000,
semiMinorAxis:5000,
material: new Cesium.ImageMaterialProperty({
image:'images/image.png',
color: new Cesium.Color(1.0, 1.0, 1.0, 0.99)
rotation : Cesium.Math.toRadians(-168),
stRotation : Cesium.Math.toRadians(168),
granularity: Cesium.Math.toRadians(10) //Less computation due to vertices
entity.ellipse = ellipseGraphics;
entity.position = Cesium.Cartesian3.fromDegrees(1.54495, 44.94759);
var entity2 = viewer.entities.getOrCreateEntity("test2");
entity2.ellipse = ellipseGraphics;
entity2.position = Cesium.Cartesian3.fromDegrees(1.52278, 45.00838);
Regards
Cal
hannah
April 14, 2016, 3:24pm
4
Thanks Cal! It looks like this is a bug in Cesium. The image is being drawn incorrectly on one of the corners of the geometry. I’ve filed an issue here: https://github.com/AnalyticalGraphicsInc/cesium/issues/3851
Hannah
hannah
October 18, 2016, 6:36pm
5
Hi Cal,
We tested this issue in Cesium 1.26 and it appears to be fixed: https://github.com/AnalyticalGraphicsInc/cesium/issues/3851
Let me know if you can still reproduce this.
Thanks!
Hannah
