Following up from 2014 review, let’s talk about what is on the roadmap for 2015. The AGI team is looking at these broad areas:
High-level Entity API
KML
Polygon, polylines, billboards, and labels clamped to terrain
Streaming 3D buildings
Streaming point clouds
Streaming vector tiles
WebGL 2
More tutorials and demos. More outreach in general. Google Summer of Code.
Of these, what do you need most? Besides these, what else is important to you?
3D buildings would be fantastic. I hope to pair Cesium with Google Streetview splitscreen style like I did with Google Earth and Google Streetview
Without 3D buildings it becomes difficult to navigate this way. Would the buildings be manually created, or through automated methods such as photogrammetry?
Height above terrain would be nice, for proper movement scaling. I’ve tried scene.globe.getHeight with no luck so far.
KML support and terrain clamping are probably at the top of my list of needs.
Between better tutorials and high level entity api/implicit properties, I'd say that implicit properties is probably higher priority, since it would invalidate a lot of older demos anyway.
I'll echo the calls for Clamped to Ground (and add models to the list) and outreach and add WebGL 2. Regardless, I'll continue to enjoy the solutions the Cesium community develops here. Best New Year to all... Erik
KML support and Clamped to Ground are as well the most important for me.
KML support will make things easier and faster to quickly display content on the cesium globe.
I’m glad to see the interest in KML and terrain clamping as I think these will be the first major new features we see in Cesium in 2015! We’ll start separate threads for the details.
@HyperSonic: awesome video, would love to see that in Cesium. AGI is talking to partners about supplying 3D building data so the details of the data acquisition method are TBA.
Streaming 3D buildings (or large number of 3D objects?)
More tutorials and demos. (Personally found converting collada to gltf are tricky)
Just wanna ask, sorry if wrong place, if it’s possible to streaming large number of 3D buildings, like a city, in Cesium now? Possible to use quantized-mesh terrain? (like to stream 3D buidling meshes instead of terrian)
Out of curiosity, do you have specific concerns regarding footprint and start up time? For example, in my opinion, the deployed Viewer reference app is pretty compact and starts up instantly, even, with an empty cache: http://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/index.html
Also, are you using the AMD modules? While using the combined Cesium.js file is the easiest thing to do, using Cesium as a set of AMD modules via requireJS or browserify will reduce the footprint to only the features you actually use. This, combined with minification works really well most of the time.
Obviously there’s always room for improvement, which is why I was curious as to the specifics.
Maybe Helge is speaking about resources footprint?
Cesium default main loop renders also when there is nothing to do,
leading to high CPU/GPU consumption. Especially for smartphones, it
would lead to a better user experience if only necessary renderings
where done. I recently talked with Patrick about this and it is not easy
stuff.
Loading time may feel 'long' when the camera starts positioned closed to
the terrain: Cesium loads all the imageries and terrain tiles above.
It may be very long if you have many layers.
I wrote a small patch to use a local, transparent, image for smaller
zoom levels. It significantly speeds up loading with several slow layers.
See https://github.com/gberaudo/cesium/tree/transparent_low_zoom
Thanks Patrick! I do plan to do this for Cesium, for now without 3D buildings I could instead rise the camera many meters over the street and look at the imagery of the street side buildings with a 45deg tilt. All I have to do is a 45deg offset between the 2 view tilts. I’ll do a mockup video in GE for now to see how it works in practice.
One cool thing about Google Streetview is the ability to dynamically change FOV_zoom. You can’t dynamically change FOV_zoom in GE, but you can in Cesium. So once Cesium gets 3Dbuildings this splitscreen setup will be even better than it is now! (I say FOV_zoom since ‘zoom’ has become ambiguous: longitudinal translation or FOV camera zoom.)
I suppose using methods such as photogrammetry and LIDAR one is basically obtaining high resolution terrain data. One could view buildings simply as boxy mountains with very steep slopes! I suppose 3Dbuildings is a misnomer if that is their source. Everything is captured this way, be it trees, hills, vehicles, ships, bridges.
Thanks everyone! I just want to make one last call for feedback if anyone else wants to chime in with their support for features already mentioned or new ones.
@Narco:
Not without coding something custom, which some folks have done. I don’t think it will take us long to get an initial version out in core Cesium.
