Cesium ION 1.9.0 frontend failed on k8s node with older VM
I tried running Cesium ION 1.9.0 in a vSphere–Kubernetes environment. However, the Cesium ION frontend (version 1.9.0) does not run on such a k8s node. It crashes at startup.:
Fatal glibc error: CPU does not support x86-64-v3
Nodes doesn’t support the following CPU features:
avx2, bmi1, bmi2
Cesium ION Frontend Version 1.8.0 works.
Hi remo,
Thanks for letting us know about that problem. Our team has created an issue to track it and investigate it further.
