Cesium ION is failed to generate tile since April 18th. We have multiple assets in Cesium ION that are stuck in retrieving file from S3. It always shows Retrieving files… 5%.
Could someone in cesium team check this issue?
Hi, Thank you for reporting this.
We are aware of this issue and actively working on fix. Will will update the thread with the original report when a fix is available.
The issue is related to the key property. To work around this while we release a fix you can use the prefix property instead.
I just tried prefixes instead, but it also doesn’t work.
