Cesium-materials-pack Deprecated?
We are making a application that provides realtime information on vehicles based on GPS position. As a way to distinguish which areas are supported, we are currently rendering roads on top of the terrain.
We first tried using the ImageMaterialProperty but the we wanted it to automatically update the repeat without having to set any number on our end. For that we followed the answers on this topics: using-wallpaper-material-with-primitive-collection and repeating-image-pattern but “Texture2D” is no longer supported.
Afterwards, I tried to create/use the material “Asphalt” described on the cesium-materials-pack I have noticed that it is no longer supported and the materials no longer work.
The code to create a using the image anchor to calculate the amount of repeats:
//Call this once at application startup
Cesium.Material._materialCache.addMaterial('Wallpaper', {
    fabric : {
        type : 'Wallpaper',
        uniforms : {
            image : Cesium.Material.DefaultImageId,
            anchor : new Cesium.Cartesian2(0, 0)
        components : {
            diffuse : 'texture2D(image, fract((gl_FragCoord.xy - anchor.xy) / vec2(imageDimensions.xy))).rgb',
            alpha : 'texture2D(image, fract((gl_FragCoord.xy - anchor.xy) / vec2(imageDimensions.xy))).a'
    translucent : false
//Create an instance and assign to anything that has a material property.
//scene - the scene
//image - the image (I think both a url or Image object are supported)
//anchor - A Cartesian3 that is the most southern and westard point of the geometry
var WallPaperMaterialProperty = function(scene, image, anchor) {
    this._scene = scene;
    this._image = image;
    this._anchor = anchor;
    this.definitionChanged = new Cesium.Event();
    this.isConstant = true;
WallPaperMaterialProperty.prototype.getType = function(time) {
    return 'Wallpaper';
WallPaperMaterialProperty.prototype.getValue = function(time, result) {
    if (!Cesium.defined(result)) {
        result = {
            image : undefined,
            anchor : undefined
    result.image = this._image;
    result.anchor = Cesium.SceneTransforms.wgs84ToDrawingBufferCoordinates(this._scene, this._anchor, result.anchor);
    if(Cesium.defined(result.anchor)){
        result.anchor.x = Math.floor(result.anchor.x);
        result.anchor.y = Math.floor(result.anchor.y);
    } else {
        result.anchor = new Cesium.Cartesian2(0, 0);
    return result;
WallPaperMaterialProperty.prototype.equals = function(other) {
    return this === other || //
           (other instanceof  WallPaperMaterialProperty && //
            this._image === other._image);
//Here's a working example.
    polygon : {
        hierarchy : Cesium.Cartesian3.fromDegreesArray([-115.0, 37.0,
                                                        -115.0, 32.0,
                                                        -107.0, 33.0,
                                                        -102.0, 31.0,
                                                        -102.0, 35.0]),
        material : new WallPaperMaterialProperty(viewer.scene, '../images/checkerboard.png', Cesium.Cartesian3.fromDegrees(-115.0, 31))
Code to reuse the “Asphalt” material:
    fabric : {
                type : "Asphalt",
                uniforms : {
                    color : new Color(0.15, 0.15, 0.15, 1.0),
                    bumpSize : 0.2,
                    roughness : 0.2
                source : `
                  uniform vec4 asphaltColor;
                  uniform float bumpSize;
                  uniform float roughness;
                  czm_material czm_getMaterial(czm_materialInput materialInput)
                      czm_material material = czm_getDefaultMaterial(materialInput);
                      // From Stefan Gustavson's Procedural Textures in GLSL in OpenGL Insights
                      //Main cellular pattern
                      vec4 color = asphaltColor;
                      vec2 st = materialInput.st;
                      vec2 F = czm_cellular(st / bumpSize);
                      color.rgb -= (F.x / F.y) * 0.1;
                      //Extra bumps for roughness
                      float noise = czm_snoise(st / bumpSize);
                      noise = pow(noise, 5.0) * roughness;
                      color.rgb += noise;
                      material.diffuse = color.rgb;
                      material.alpha = color.a;
                      return material;
We wanted to add a texture to the created roads not just a solid colour. However, if we use ImageMaterialProperty the look degrades significantly onZoom.
So our objective would either be creating a material with the look and feel of “Asphalt” or somehow creating another MaterialProperty that automatically updates the “repeat” to adapt the number of repetitions for each different “zoom”.
Is there any way in which we can achieve our objective?
  • Cesium Version: 1.105.2
  • Browser: Google Chrome
  • Operating System: MacOS Ventura
I can not make an official statement about the cesium-materials-pack, but … the fact that the repository is ‘archived’ suggests that it is not the recommended approach for doing things.
I also cannot say what’s wrong with the ‘Asphalt’ material. But it sounds like you only tried out the ‘Asphalt’ material as a workaround for another problem, namely that
… “Texture2D” is no longer supported.
Iff this is the root cause for the issue: It was renamed from texture2D to texture. Just renaming the function in the sandcastle that you provided seems to work:
If that doesn’t solve the issue, then someone else may have to chime in here.
It indeed work, just replacing the “Texture2D” by “Texture”. The problem I have found now is that as the material recalculates the anchor every frame, as soon as you use it on a big enough/several entities, it crashes.
By any chance is there any way of preventing the recalculation on every frame, or any other way of setting an image texture that would no degrade onZoom?
From the error message alone, it is not clear what causes this error. Are you sure that it is related to the material/texture? (Maybe posting a Sandcastle or at least a stack trace from an unminified CesiumJS instance could help, but someone may have to allocate some time to investigate that further…)
Sorry for the late reply, I was busy checking some optimisations, so it took me a while to visit the error.
You were absolutely right, the problem was not related with the material, but with a PolylineVolume I was interpolating points in.
Now the material works perfectly, but it moves more than what I would have expected, so when Zooming in and out more than static asphalt it looks like a conveyor belt…
Would there be any other way of using an * ImageMaterialProperty without specifying the number on the repeat, or calculating a function that calculates it automatically without causing a “flicker” effect while rendering the new repeat of the material?
It’s not entirely clear what you mean, but … I also noticed that the (checkerboard) texture from an earlier example seemed to be “moving” in a way that I wouldn’t expect. I modified the sandcastle a bit (admittedly, just with some “trial and error” in the fabric definition), and think that this can be reduced - here’s an example of ‘before’ and ‘after’:
Cesium TextureShader
The modified sandcastle:
(Only the fabric.components.diffuse line is changed - apply the same to alpha is this works for you)
Yes, that is exactly what I meant.
I have been modifying the diffuse & alpha and although it still “moves”, it has significantly improved.
