Its based upon sample code provided on this forum.
Here is a Sandcastle example that illustrates the issue ( Thanks Diana! ):
This
goes into the HTML/CSS tab:
@import url(../templates/bucket.css);
Loading...
This goes into the Javascript tab:
//Call this once at application startup
Cesium.Material._materialCache.addMaterial(‘Wallpaper’, {
fabric : {
type : ‘Wallpaper’,
uniforms : {
image : Cesium.Material.DefaultImageId,
anchor : new Cesium.Cartesian2(0, 0)
components : {
diffuse : ‘texture2D(image, fract((gl_FragCoord.xy - anchor.xy) /
vec2(imageDimensions.xy))).rgb’,
alpha : ‘texture2D(image, fract((gl_FragCoord.xy - anchor.xy) /
vec2(imageDimensions.xy))).a’
translucent : false
//Create an instance and assign to anything that has a material property.
//scene - the scene
//image - the image (I think both a url or Image object are supported)
//anchor - A Cartesian3 that is the most southern and westard point of the
geometry
var WallPaperMaterialProperty = function(scene, image, anchor) {
this._scene = scene;
this._image = image;
this._anchor = anchor;
this.definitionChanged = new Cesium.Event();
this.isConstant = true;
WallPaperMaterialProperty.prototype.getType = function(time) {
return ‘Wallpaper’;
WallPaperMaterialProperty.prototype.getValue = function(time, result) {
if (!Cesium.defined(result)) {
result = {
image : undefined,
anchor : undefined
result.image = this._image;
result.anchor = Cesium.SceneTransforms.wgs84ToDrawingBufferCoordinates(this._scene,
this._anchor, result.anchor);
if(Cesium.defined(result.anchor)){
result.anchor.x = Math.floor(result.anchor.x);
result.anchor.y = Math.floor(result.anchor.y);
} else {
result.anchor = new Cesium.Cartesian2(0, 0);
return result;
WallPaperMaterialProperty.prototype.equals = function(other) {
return this === other || //
(other instanceof WallPaperMaterialProperty && //
this._image === other._image);
//Here’s a working example.
Sandcastle.addToolbarButton(‘Test1’, function() {
var customDataSource1 = new Cesium.CustomDataSource("testing");
viewer.dataSources.add(customDataSource1);
var customRectangle = customDataSource1.entities.add({
id
: “rect1”,
rectangle
coordinates
: Cesium.Rectangle.fromDegrees(-119, 44, -112, 47),
material
: new WallPaperMaterialProperty(viewer.scene,
“…/images/checkerboard.png”, Cesium.Cartesian3.fromDegrees(-119,
44)),
outline
: true,
outlineColor
: Cesium.Color.RED
}, ‘test1’);
Sandcastle.addToolbarButton(‘Test2’, function() {
var customRectangle2 = viewer.entities.add({
id
: “rect2”,
rectangle
coordinates
: Cesium.Rectangle.fromDegrees(-110.0, 20.0, -80.0, 25.0),
material
: new WallPaperMaterialProperty(viewer.scene, “…/images/checkerboard.png”,
Cesium.Cartesian3.fromDegrees(-110, 20)),
outline
: true,
outlineColor
: Cesium.Color.RED
}, ‘test2’);
Let me know if you need anything else.
Lori
