Cesium Navigation - what means rotate tilt view
could anyone explain the behaviour of the Navigation - is there any documenation.
Pan view, Zoom view and Rotate view and in the touch UI the tilt view.
Zoom - change of Camera-Position (–> camera moveForward and moveBackward)
Pan - change Camera (moveUp, moveDown, moveLeft, moveRight
What is done at rotation and tilt ? Are these changes of the orientation ?
Regards
1.63
