When I export an ephemeris from STK and load it into Cesium, the orbit shown by Cesium does not match the orbit shown by STK.
let viewer = new Cesium.Viewer('cesiumContainer');
viewer.clock.currentTime = {dayNumber: 2458212, secondsOfDay: 42161};
let satellite = new Cesium.CzmlDataSource;
satellite.load('./czml/20580.czml');
viewer.dataSources.add(satellite);
Output from STK:
stk.v.11.0
# WrittenBy STK_v11.3.0
BEGIN Ephemeris
NumberOfEphemerisPoints 1441
ScenarioEpoch 3 Apr 2018 00:00:00.000000
# Epoch in JDate format: 2458211.50000000000000
# Epoch in YYDDD format: 18093.00000000000000
InterpolationMethod Lagrange
InterpolationSamplesM1 5
CentralBody Earth
CoordinateSystem Fixed
# Time of first point: 3 Apr 2018 00:00:00.000000000 UTCG = 2458211.50000000000000 JDate = 18093.00000000000000 YYDDD
EphemerisTimePosVel
0.0000000000000000e+00 -4.5359764575516172e+06 -5.1607743254736066e+06 7.8450448190850485e+05 4.4020439857647179e+03 -4.4121431216952478e+03 -3.5181212882812092e+03
6.0000000000000000e+01 -4.2633659746787520e+06 -5.4153372021275945e+06 5.7186106703641638e+05 4.6821636433380363e+03 -4.0705953408420937e+03 -3.5673772905035821e+03
1.2000000000000000e+02 -3.9744597835689671e+06 -5.6489450263801431e+06 3.5672754495527950e+05 4.9450586788787823e+03 -3.7138731467569614e+03 -3.6010946415013723e+03
1.8000000000000000e+02 -3.6703219200022179e+06 -5.8607289135145778e+06 1.4004087407265083e+05 5.1897217377712914e+03 -3.3433716467381305e+03 -3.6191301790898519e+03
2.4000000000000000e+02 -3.3520748546701646e+06 -6.0499052372829933e+06 -7.7255459084215123e+04 5.4152129892680623e+03 -2.9605366807835630e+03 -3.6214095111198794e+03
3.0000000000000000e+02 -3.0208953299297499e+06 -6.2157784988459554e+06 -2.9421557524083735e+05 5.6206637958249121e+03 -2.5668589578200181e+03 -3.6079272817916039e+03
8.6100000000000000e+04 -3.0418970521981153e+06 -6.1834822848993465e+06 -6.0170556574387930e+05 5.6963104946808426e+03 -2.4615842324743921e+03 -3.5616261309548709e+03
8.6160000000000000e+04 -2.6944042479060069e+06 -6.3192270286859050e+06 -8.1394040601075685e+05 5.8831564064111089e+03 -2.0618722431855058e+03 -3.5102602605819197e+03
8.6220000000000000e+04 -2.3363547718379921e+06 -6.4307626048556063e+06 -1.0226341556490948e+06 6.0480842638911272e+03 -1.6548757212985529e+03 -3.4436332384725238e+03
8.6280000000000000e+04 -1.9690835373093646e+06 -6.5176988908674316e+06 -1.2268796827632689e+06 6.1904472213785630e+03 -1.2421630793468501e+03 -3.3620407645807518e+03
8.6340000000000000e+04 -1.5939617414616649e+06 -6.5797404361530812e+06 -1.4257895535368568e+06 6.3096830156480883e+03 -8.2532055586322872e+02 -3.2658435326732092e+03
8.6400000000000000e+04 -1.2123917257039957e+06 -6.6166873442836497e+06 -1.6184998816606605e+06 6.4053160631113433e+03 -4.0594596881778750e+02 -3.1554655083608768e+03
END Ephemeris
Input CZML:
{"id": "document", "version": "1.0"},
"id": "Hst",
"name": "Hst",
"position": {
"epoch": "2018-04-03T00:00:00",
"cartesian": [
0.0, -4535976.457551617, -5160774.325473607, 784504.4819085049,
60.0, -4263365.974678752, -5415337.2021275945, 571861.0670364164,
120.0, -3974459.783568967, -5648945.026380143, 356727.5449552795,
180.0, -3670321.920002218, -5860728.913514578, 140040.87407265083,
240.0, -3352074.8546701646, -6049905.237282993, -77255.45908421512,
300.0, -3020895.32992975, -6215778.498845955, -294215.57524083735,
86100.0, -3041897.0521981153, -6183482.2848993465, -601705.5657438793,
86160.0, -2694404.247906007, -6319227.028685905, -813940.4060107569,
86220.0, -2336354.771837992, -6430762.604855606, -1022634.1556490948,
86280.0, -1969083.5373093646, -6517698.890867432, -1226879.682763269,
86340.0, -1593961.741461665, -6579740.436153081, -1425789.5535368568,
86400.0, -1212391.7257039957, -6616687.34428365, -1618499.8816606605],
"referenceFrame": "Fixed"
"label": {"text": "Hst"},
"point": {
"color": {"rgba": [255, 0, 0, 255]},
"pixelSize": 5.0,
"outlineColor": {"rgba": [255, 255, 255, 255]},
"outlineWidth": 2.0
"path": {
"width": 1,
"leadTime": 3000,
"trailTime": 3000,
"resolution": 120,
"material": {"solidColor": {"color": {"rgba": [255, 0, 0, 255]}}}
I was not able to find how to include an attachment, otherwise I would have attached the output ephemeris and czml files.
Cesium 1.43.0
Both Centos7 w/Firefox and Windows10 with Chrome
