I am currently working on Cesium.js 1.96 and trying to visualize a space mission scenario including 2 satellites. And im tring to draw the path of a satellite while the orbit’s reference frame is the other’s local orbit frame. As the visiualization in STK showing below:
However, i have never successed in visualizing this scenario, neither using referenceFrame: #id in CZML nor loading the czml exported from stk works. They all end up with this in Cesium:
And i have read some posts in github and cesium community about this, it seems that the discussion about relative reference frame in cesium started in 2013, and the reference frame branch had been merged into ‘main’ in 2017? But i still can’t make it work
Well, this explains why STK CZML Export Plugin can’t export orbits in my defined reference frames. But still, is it available for Cesium or CZML to load a orbit graphic that its reference frame is another entity?
Sorry for the late reply.
Im more familiar with Orekit compared to CesiumJS, so that the implementation was in Java. But still, the idea was to propagate and transform the trajectory sampling points, shown below.
Im sure this can be done with coordinate transform methods in Cesium and propagate method in SatelliteJS too.
Again, sry for my super late reply
Hello @paopao99 , I would like to display a relative motion between two satellites as you did using Orekit. I’m able to compute the relative position of the 2nd satellite wrt to the first one with Orekit. I am just struggling with displaying the relative motion in Cesium. How did you manage to plot the green relative motion between the two satellites once you know the relative position ? Thanks!
