I configured webpack and cesium according to the official website tutorial.
But there are three warnings in the process of operation:
WARNING Compiled with 3 warnings 19:43:45
warning in ./node_modules/_cesium@1.46.1@cesium/Source/Core/TaskProcessor.js
150:80-87 Critical dependency: require function is used in a way in which dependencies cannot be statically extracted
warning in ./node_modules/_cesium@1.46.1@cesium/Source/Core/buildModuleUrl.js
56:15-22 Critical dependency: require function is used in a way in which dependencies cannot be statically extracted
83:77-84 Critical dependency: require function is used in a way in which dependencies cannot be statically extracted
How to solve these warnings? How will these warnings affect the development environment or the compilation environment?
I configure the webpack and cesium:
https://github.com/ShareQiu1994/CesiumWebpackVueCli
I want to build a framework based on webpack, cesium and Vue
cesium 1.46
chrome 63
Thanks Liu
