Compile Error in webpack project
when I try to use the new packages “@cesium/engine” and “@cesium/widgets” in my Angular / Webpack project, I get a number of compiler warnings and errors like:
Warning: /path/to/project/node_modules/@cesium/widgets/Source/VRButton/VRButtonViewModel.js depends on 'nosleep.js'. CommonJS or AMD dependencies can cause optimization bailouts.
For more info see: https://angular.io/guide/build#configuring-commonjs-dependencies
and
./node_modules/@cesium/engine/Source/Core/Resource.js:1843:15-28 - Error: Module not found: Error: Can't resolve 'url' in '/path/to/project/node_modules/@cesium/engine/Source/Core'
What is missing or wrong here?
Hi @google
You may need to provide some additional options for Webpack to resolve modules like url, http, https and zlib, as is shown in the cesium-webpack-example.
I’m not that familiar with Angular to provide a proper answer for those warnings, but I hope the step recommended above will resolve the build errors.
Sam.
Hello @google :wave:
For the warning message, you will need to modify your angular.json file according to the information that is described in the provided link.
Thanks, I was a bit confused, that the Cesium code is actually being compiled. I was expecting the package to ship an already compiled version.
Nevertheless, I finally managed to get everything compiled. I had to add some additional dev-dependencies:
  • assert
  • browserify-zlib
  • https-browserify
  • stream-browserify
  • stream-http
  • url
Would be great, if these could be added as peer-dependencies to the package.json file in Cesium, so that users are notified about that, or as direct dependencies, so they are installed automatically.
Besides, I had to add patch settings in tsconfig.json:
"paths": {
    "http": [
        "node_modules/stream-http"
    "https": [
        "node_modules/https-browserify"
    "stream": [
        "node_modules/stream-browserify"
    "zlib": [
        "node_modules/browserify-zlib"
In addition, I had to a dd a bunch of entries in angular.json:
"allowedCommonJsDependencies": [
    "nosleep.js",
    "grapheme-splitter",
    "bitmap-sdf",
    "jsep",
    "urijs",
    "zlib",
    "url",
    "http",
    "https",
    "earcut",
    "mersenne-twister",
    "protobufjs/dist/minimal/protobuf.js"
Now, everything compiles and runs fine.
I have to correct myself. Using the current version of @cesium/engine and @cesium/widgets results in a compile error:
Error: node_modules/@cesium/widgets/index.d.ts:2052:26 - error TS2304: Cannot find name 'ContextOptions'.
2052         contextOptions?: ContextOptions;
It looks as if ContectOptions is missing in the import statement.
If I use the combined package, the error does not appear.
Glad you got things working!
There is a pre-built version shipped in Build/Cesium and Build/CesiumUnminified. However, if you are using a bundler such as webpack, it’s recommended to use the Source modules as you will benefit from optimizations such as tree shaking and dead code elimination.
Thanks for the report! I think this is an error when generating typescript definition for the widgets package.
Opened ContextOptions is not properly imported to to the @cesium/widgets package · Issue #10963 · CesiumGS/cesium · GitHub to track the issue.
