Cesium1.54 bug?
I added an entity using viewer.entities.add and found that there is one extra for the scene.primitives array; but when I use viewer.entities.removeAll(), the extra content in the scene.primitives array is not deleted.
viewer.entities.add({
polyline: {
   positions: ,
   width:5
Cesium1.54 windows64 Google Chrome
It’s hard to tell if it’s a bug or not, it could be that it’s saving the primitive to re-use or delete later. Have you tried adding more entities to see if that extra one remains?
Does the same thing happen in CesiumJS 1.53?
