Hi Cesium team,
I have encounted some issues when working with Polyline collections. The following code will throw an error when using either kind of removeAll when removing more than one polyline at a time.
var scene = viewer.scene;
scene.primitives.add(new Cesium.PolylineCollection());
scene.primitives.add(new Cesium.LabelCollection());
var material3 = Cesium.Material.fromType(‘Color’);
var polylines = scene.primitives.get(0);
var poly;
var labels = scene.primitives.get(1);
var index=0;
for (index = 0; index < 5; index++) {
var positions = [ -96+index, 30+index, -98+index, 32+index ];
positions = Cesium.Cartesian3.fromDegreesArray(positions);
poly=polylines.add({
positions : positions,
width : 2,
material: material3
poly.material.uniforms.color = Cesium.Color.AQUA;
labels.add({
position : Cesium.Cartesian3.fromDegrees(-96+index, 30+index),
text : ‘A label’+index
polylines.removeAll();
//scene.primitives.removeAll();
Changing the polylines.add material parameter to the following fixed the issue.
material: Cesium.Material.fromType(‘Color’)
So I assume that this has something to do with passing a material by reference or something. Will things stay this way? On a side note I noticed a syntax error in the PolylineCollection documentation in the first example. the ‘positions’ property is spelled ‘position’ for the first polyline.
http://cesiumjs.org/Cesium/Build/Documentation/PolylineCollection.html?classFilter=polylinecoll
Another question I had was whether there were plans to bring back the Geometry and Appearances SandCastle back to using Geometries instead of entities. It has some great examples that I used.
Matt
