[Polylines] Problem when removing multiple polyline with material properties
Hi !
I’m having an issue, detailed here:
https://stackoverflow.com/questions/41381988/how-to-correctly-remove-a-cesium-polyline
This is not my post, but i have the same issue.
**When i try to remove multiple polylines (actually, entities containing polyline and wall) within a for loop, some polyline doesn’t remove. **
Some of the polylines are still displayed, but NOT the wall.
The problem occurs only when the polyline material is dash or outline material.
If i use only Cesium.COLOR it works fine !
I use Cesium 1.37, chrome lastest version.
I’ll try Cesium 1.38 to see if the bug is still here, and update you.
Thanks for looking a this !
Love you work !
Hi Benjamin,
I was able to duplicate this bug in the Polylines Sandcastle example by adding the following loop to remove the polylines:
Sandcastle.addToolbarButton(‘Remove polylines’, function() {
for (var i = 0; i < viewer.entities.values.length; ++i) {
    viewer.entities.remove(viewer.entities.values[i]);
If I hit that button, not all of the polylines are removed, but if I do it several times, they will be eventually removed.
I opened Issue #5893 to track this, please add any additional info there if you have any.
Thanks!
Gabby
Try this loop to remove them correctly:
Sandcastle.addToolbarButton('Remove polylines', function() {
    while (viewer.entities.values.length > 0) {
        viewer.entities.remove(viewer.entities.values[0]);
