So I have ran into an issue when using PolylineOutlineMaterialProperty,
If I have multiple entities that are constantly updating their polylines, and I try to display them using the PolylineOutlineMaterialProperty,
I get an error like this (scroll down for reproduction steps and sandcastle example) :
Here’s my code (instructions follows below)
// This flag determines which material type to use on a polyline
var isOutlineMaterialUsed = false;
// Keep here the interval id to be able to stop updates
var intervalId;
Sandcastle.addDefaultToolbarButton(‘ColorMaterial’, function () {
// The polyline will use a ColorMaterial
Sandcastle.addToolbarButton(‘PolylineOutlineMaterial’, function () {
// The polyline will use a PolylineOutlineMaterial
isOutlineMaterialUsed = true;
Sandcastle.addToolbarButton(‘Resume Updates’, function () {
// Start updating the entities
intervalId = setInterval(updateEntities, 2000);
Sandcastle.addToolbarButton(‘Stop Updates’, function () {
// Stop updating the entities
if (intervalId) {
intervalId = clearInterval(intervalId);
// Create and add a datasource
var dataSource = new Cesium.CustomDataSource(‘myDataSource’);
// Create an array to store the entities, just for easier access
var entityData = ;
// Prepartion code to create entities
var lon = -80.0;
var lat = 40.0;
- Given an amount, creates entities near each other with a random color
function createEntities(amount) {
for (var idx = 0; idx < amount; idx++) {
// Move the entity slightly off by longitude
var currentLongitude = lon + (idx * 0.01);
var startPosition = Cesium.Cartesian3.fromDegrees(currentLongitude, lat);
// Add the entity with a point graphics of a random color
var entity = dataSource.entities.add({
id: 'entity' + idx,
point: {
pixelSize: 12,
color: Cesium.Color.fromRandom({ alpha: 1.0 }),
outlineWidth: 2.0,
outlineColor: Cesium.Color.BLACK
position: startPosition
// Store the entity data for easier access later
entityData.push({
positions: [[currentLongitude, lat]],
positionsCartesian: [startPosition],
entity: entity,
Invoked in intervals, updates all entities to a new position, by shifting the latitude a bit northern from it’s current location.
Each time, a point is added to a polyline. This simulates updates from a server
function updateEntities() {
// Iterate over the entity data kept earlier
for (var e of entityData) {
// Take the last saved position and add an offset to the latitude
var lastPositionDegrees = e.positions[e.positions.length - 1];
var newPosition = [
lastPositionDegrees[0],
lastPositionDegrees[1] + 0.005
// Store the new position, and convert to cartesian
e.positions.push(newPosition);
var newCartesian = Cesium.Cartesian3.fromDegrees(newPosition[0], newPosition[1]);
e.positionsCartesian.push(newCartesian);
// The polyline's color will be the entity's color
var materialColor = e.entity.point.color.getValue(0);
var material;
// Create the material based on user's selection
if (isOutlineMaterialUsed) {
// This causes a strange buggy behaviour eventually leading to an exception!
material = new Cesium.PolylineOutlineMaterialProperty({
color: materialColor,
outlineWidth: 4.0
} else {
// Create a simple color material
material = new Cesium.ColorMaterialProperty(materialColor);
// Each update, create a new polyline for the entity, using the accumulated positions,
// the material created above and a constant width.
e.entity.polyline = {
positions: e.positionsCartesian.slice(),
material: material,
width: 6.0
// Move our entity to the new position
e.entity.position = newCartesian;
// Create two entities to demonstrate the bug
createEntities(2);
// Zoom to our entities
viewer.zoomTo(dataSource);
Run the example
Click ‘Resume Updates’
After the polylines begin to grow, click ‘PolylineOutlineMaterial’ button,
Watch how the polylines dissapear except the first
Click on the point whose polyline have dissapeared - exception!
If I use ColorMaterial, everything works fine. Look at the provided screenshot - when switching to a PolylineOutlineMaterial, the second polyline dissappears
The problem is related to a missing primitive when calculating the bounding sphere inside StaticGeometryPerMaterialBatch class.
I’m here for further explaining if I wasn’t so clear about the issue,
Thanks!
-Mati
