How to remove primitives from a collection (or the collection itself) without developer error exception
In spite of online searches and the apparently easy ‘emptying a collection’ task, I don’t know how to remove (and destroy at the same time) all primitives from a primitive collection or remove the collection itself from the scene.
Using the collection#remove() or collection#removeAll() methods both fail with “Uncaught DeveloperError: This object was destroyed, i.e., destroy() was called.”
A Sandcastle-ready code example follows.
var scene = viewer.scene;
var polyline;
var material = Cesium.Material.fromType(‘PolylineArrow’);
material.uniforms.color = new Cesium.Color(0,1.0,0,1.0);
var polylines = scene.primitives.add(new Cesium.PolylineCollection());
polyline = polylines.add({
positions : Cesium.PolylinePipeline.generateCartesianArc({
positions : Cesium.Cartesian3.fromDegreesArray([-110.0, 42.0,
-77.0, 12.0])
width : 10.0,
show : true,
material: material
polylines.add({
positions : Cesium.Cartesian3.fromDegreesArray([-120.0, 42.0,
-77.0, 12.0])
width : 10.0,
show : true,
material: material
// Both the following ways fail to remove all the primitives,
// how to do it properly?
//setTimeout(()=> { scene.primitives.remove(polylines); },2000 );
setTimeout(()=> { polylines.removeAll(); },2000 );
I need to remove and destroy all polyline primitive I previously created to replace them with freshly created others.
Cesium 1.59, Win 10 64Bit, Chrome 75.0.3770.100 64 bitt official build
TIA
Bump
Looks like this is a known bug, and it happens specifically because the polylines share a material, see: https://github.com/AnalyticalGraphicsInc/cesium/issues/1567
The suggested fix is to have a material per polyline.
Thanks Omar, any chance that bug will be fixed? (I have many primitives and a shared material would be the right way to go)
