This seems like it should be something extremely straight forward but I don't think I've ever been able to get it to work correctly. Trying to remove all primitives using the removeAll() function always results in the following error message:
and then the globe locks up and the page has to be refreshed. Am I missing something? Looking in the SandCastle, I see examples where primitives.removeAll() is called and it seems to work normally.
I do that already. I have a large utility class that I have created call CesiumHelper that provides alot of convenience functions and such. When that class initializes, it initializes the globe and then sets up variables (class attributes in this instance) for the viewer, scene, ellipsoid, and primitives.
I wouldn't think so unless Cesium itself had already destroyed them. At the point that I'm testing this, I just load a few things on the globe and attempt a removeAll() and get the error. Looking at that function definition and thinking about your reply though.. do you mean that, if I create a PolylineCollection and then add 5 lines to it, that if I call removeAll() that it could remove and destroy the Polyline's before the collection and that then the PolylineCollection would attempt to delete them as well? Or I misunderstanding this?
Perhaps, short term until I can figure this out I should just make a custom removeAll() that destroys things in a specific order..
I think I may have found the problem and, reason being is that I didn't understand how some aspects of this functioned before. It makes sense looking at it now but I wasn't thinking of a texture atlas as being one of the items that would be destroyed in the process. When a billboard collection is removed, it's texture atlas is also destroyed. Unaware that this happened, I was sharing a texture atlas between several billboard collections. So, when I attempted a remove all, it was destroying a shared resource essentially. It's weird though that, calling remove all doesn't fail after the first item is removed. Nothing was ever removed.
Long story, short.. it was an issue of an item being destroyed already.
BillboardCollection has a destroyTextureAtlas property which you can set to false if you want to share a texture atlas. You’ll then be responsible for destroying the shared texture atlas in your own code when cleaning up.
removeAll works by iterating the primitives, destroying each one, then clearing the collection afterwards, which is why you saw the behavior you mention.
