cesiumjs+threejs
Hello, I saw the development of the cesium+three update you on your blog, I in your code to achieve the obj+mtl model of the load model, but corresponding position can’t be loaded successfully, there was a problem is when my mobile obj model will appear jitter, you can solve this problem?
Do you see the jittering only on mobile?
Also are you able to share the code you’re using?
Hello this is my code to implement the model effect:
https://github.com/gaojunxiaowwww8888/gjxCreate.git
在 2017年12月5日星期二 UTC+8上午8:08:10,Sean Lilley写道:
Just to experiment I created a branch which loads an obj: https://github.com/lilleyse/cesium-threejs-experiment/tree/obj-example
Hope that helps.
Can you set the view matrix by other methods?
Now I want to use ceium with Cocos creator(https://www.cocos.com/en/creator-download), but the camera’s view matrix cannot be set in Cocos creator, so is there any other way to set the view matrix? Thank you
