Unity hard-crashes (no managed exception, process killed by OS) shortly after removing a CesiumPolygonRasterOverlay while a Google Photorealistic 3D Tiles tileset is loading/refining tiles. The crash is in CesiumForUnityNative.dll in C++ native code.
This might be related to the Unreal report here: Google Photorealistic 3D Tiles Cause Crashing with CesiumPolygonRasterOverlay polygons populated
That thread identified the crash location as RasterOverlayTile::~RasterOverlayTile() – the ActivatedRasterOverlay is destroyed before the last RasterOverlayTile it created completes. The cesium-native v0.55.0 changelog mentions a fix for exactly this pattern (“Fixed a bug that could cause an ActivatedRasterOverlay to be destroyed before the last RasterOverlayTile it created, leading to a crash”), but a crash is still reproducible on v0.58.0.
Steps to reproduce
A minimal reproduction project is attached: cesium_cutout_polygon_crash.zip (38.0 KB)
- Extract and open in Unity 6000.2.15f1
- Set
CesiumSetup._googleApiKeyto a valid key - Enter Play mode
- Click “Set Polygon Overlay” button (or press P)
- Optionally rotate the camera slightly to trigger tile refinement
- Click “Remove Polygon Overlay” button (or press O)
- Wait a few seconds – Unity hard-crashes
Sometimes it is needed to repeat steps 3 to 7 multiple times and move the camera more to reproduce.
The “Remove” implementation calls Destroy(_polygonRasterOverlay) and Destroy(_polygonObject), which is the standard Unity approach. The crash occurs during subsequent tile loading/refinement in Cesium3DTileset.Update().
Workarounds investigated
We tried several approaches, each reducing crash frequency but none fully eliminating it:
1. Clear polygons list before destroy
_polygonRasterOverlay.polygons?.Clear();
UnityEngine.Object.Destroy(_polygonRasterOverlay);
Slightly reduced frequency.
2. Disable instead of destroy
_polygonRasterOverlay.enabled = false;
Further reduced frequency.
3. Never destroy – reuse with empty spline (most stable)
// "Remove" just sets an empty polygon list instead of destroying:
SetPolygonRasterOverlay(Array.Empty<Point3d>());
The _polygonObject and _polygonRasterOverlay are created once and never destroyed. “Removing” the overlay updates the spline in-place to an empty polygon. This keeps the native ActivatedRasterOverlay alive permanently and has proven the most stable in practice, though we cannot confirm it is fully crash-free under all conditions.
Expected behavior
Removing a CesiumPolygonRasterOverlay component while a tileset is active should not crash.
