Change Height in 3Dtiles
I produce 3dtiles whith Bently Context Capture,the product can display rgiht in cesium,but It’s below the ground,I want to Add Height to All the json and b3dm files ,Is there some way?
Hi there,
If you need to do a simple translation of a 3d tileset (like adjust height), you can try code like this example: https://groups.google.com/d/msg/cesium-dev/CqYeu6L6bhU/P0WywsBhBQAJ
Hope that helps!
  • Rachel
