I have a model of a spacecraft, which I can successfully change orientation and position with properties. I would like to have a polyline(s) coming out of the spacecraft at the same orientation, positions - emulate some sort of rays.
Basically want to show spacecraft emitting rays that travel from the vehicle to the ground.
1.45.0, windows, chrome
Hi Brian,
Could you maybe provide a sample image? I’m not sure exactly what your looking for, but I believe adding a path to your entity will be what your looking for. You can specify leadTime and/or trailTime to display a line in front of or behind your entity respectively.
Gabby
Thanks for the quick reply. Let me ask you a different question:
In the SandCastle example https://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Interpolation.html
a plane model is changing its position and orientation. There is a path that’s shown but it is not involved in calculating the position or the orientation.
Now suppose I wanted to create a polygongeometry that traveled alongside the plane that changed its position and orientation at the same times the plane did.
Is that possible?
Is that possible?
Sure, use a Callback Property for each of the properties you want to mirror, and return the value of the plane entity’s property for each.
Looks like what I’m looking for. Thanks
