Hi all,
There is something I don't really understand. The thing is when I call a function that contain this piece of code:
g_widget.scene.getPrimitives()._primitives[0].appearance.flat = true;
From the console, the flat attribute did change. However, the targeted primitive did not change the appearance.
Am I missing something?
Thank you.
Dave
Hi Dave,
The appearance didn’t change because Primitive only checks to see if there is a new appearance or the material changed. We’re going to evaluate ES5 properties that would fix this problem. Until then, the work around is to change the material or create a new appearance.
Regards,
Dan
Hi Daniel,
Thank you for clarifying this.
I've made it through yesterday on creating flat like object simply by adding "normals : 'vec(1,1,1)'" into the fabric/component.
Dave
patrick
September 11, 2013, 3:07pm
4
The flat property is explicitly marked readonly in the documentation. Unfortunately, as Dan mentioned, we can’t do a good job of enforcing it yet.
Cesium: The Platform for 3D Geospatial
Patrick
Hi Patrick,
Have just realised it. Thank you.
Dave
