I'm very new to Cesium and Javascript so please bear with me.
I am trying to add an event listener onTick so that the colour of a roof panel changes colour based on values from within my CZML. However, the roof panel remains white and no errors are thrown. The CO2 value array in the CZML is being pulled in from a google spreadsheet. My code is as follows:
viewer.clock.onTick.addEventListener(function (clock) {
var rf = dataSource.entities.getById('roof');
col = roofColour();
rf.polygon.material = col;
function roofColour() {
var c;
var bl = Cesium.Color.fromCssColorString('blue');
var gr = Cesium.Color.fromCssColorString('green');
var roof = dataSource.entities.getById('custom_roof');
var sample_co2 = roof.properties.getValue(viewer.clock.currentTime);
var co2 = sample_co2.co2value
if (co2 > 500) {
c = bl;
else {
c = gr;
return c;
And my CZML:
var czml = [{
"id" : "document",
"name" : "CZML Custom Properties",
"version" : "1.0",
"clock": {
"interval": interval,
"currentTime": time,
"multiplier": 10
"id" : "custom_roof",
"name" : "An roof with custom properties",
"properties" : {
"constant_property" : true,
"co2value" : {
"number": array
"id" : "roof",
"name" : "OlympicStadiumRoofSegment",
"description" : "A section of the Olympic Stadium Roof with an air quality sensor installed",
"polygon" : {
"positions" : {
"cartographicDegrees" : [
-0.0180193, 51.5391786, 44.892484,
-0.0176612, 51.5391213, 47.7758748,
-0.0174239, 51.5393854, 47.7758488,
-0.0173332, 51.5394864, 47.7758388,
-0.0176184, 51.5396248, 44.89244,
-0.0177748, 51.5397008, 43.3117697,
-0.0177942, 51.5396876, 43.2577824,
-0.0178749, 51.5396253, 43.0838257,
-0.0178788, 51.5396223, 43.0758278,
-0.017946, 51.539564, 42.9708558,
-0.0179916, 51.5395202, 42.9278694,
-0.018048, 51.5394594, 42.9148781,
-0.0180864, 51.539413, 42.9378777,
-0.0181221, 51.5393657, 42.9858723,
-0.0181554, 51.5393178, 43.0538624,
-0.0181656, 51.5393018, 43.0838576,
-0.0181928, 51.5392588, 43.1648447,
-0.0182199, 51.5392107, 43.2768254,
"material" : {
"solidColor" : {
"color" : {
"rgba" : 0
"perPositionHeight" : true
Thanks for any insight...
