thomlep
December 24, 2014, 8:57pm
1
I'm getting an exception when I try to change the color of a path element of an Entity imported from dragged CZML. Cesium version 1.4.
if( this.material instanceof Cesium.ColorMaterialProperty ) {
if( this.material.color ) {
// CODE BLOWS-UP HERE
this.material.color = Cesium.Color.RED;
// THIS ALSO BLOWS-UP
this.material = new $wnd.Cesium.ColorMaterialProperty( $wnd.Cesium.Color.RED );
where *this* is PathGraphics object from an Entity.
What are the errors of my ways?
Thanks for advice!
Here's the CZML segment:
<snip>
"path":{"material":{"solidColor":{"color":{"rgba":[255,255,100,100]}}},
"width":[ { "number":1.0}],
"show":[{"interval": "2014-09-03T11:45:10Z/2014-09-03T12:16:24Z","boolean":true}]
<snip>
thomlep
December 29, 2014, 2:05pm
2
I'm getting this exception: Would appreciate any shared successes. Thanks
undefined
TypeError: undefined is not a function
at Function.i.getValueOrClonedDefault (http://localhost:8080/sdat/js/cesium_1.4/Cesium.js:392:28514 )
at l.getValue (http://localhost:8080/sdat/js/cesium_1.4/Cesium.js:393:1636 )
at Function.o.getValue (http://localhost:8080/sdat/js/cesium_1.4/Cesium.js:397:29330 )
thomlep
December 29, 2014, 3:25pm
3
GOT IT! The right way:
this.material = Cesium.ColorMaterialProperty.fromColor(Cesium.Color.RED);
where 'this' is the PathGraphics object.
If you aren’t in complete control of the data (such as loading from an external file) you’ll always want to assign a new property rather than try and re-use the existing one. Here’s a simple example that loads a CZML file and assigns random colors to all entity paths when the button is clicked. You can paste the below directly into Sandcastle: http://cesiumjs.org/Cesium/Apps/Sandcastle/index.html
var gallery = ‘…/…/SampleData/’;
var czmlDataSource = new Cesium.CzmlDataSource();
czmlDataSource.loadUrl(gallery + ‘simple.czml’);
viewer.dataSources.add(czmlDataSource);
Sandcastle.addToolbarButton(‘Change colors’, function() {
var entities = czmlDataSource.entities.entities;
for(var i = 0, len = entities.length; i < len; i++) {
var entity = entities[i];
if(entity.path) {
entity.path.material = Cesium.ColorMaterialProperty.fromColor(Cesium.Color.fromRandom({ alpha: 1.0 }));
I’ll also add that we are in the process of making the high-level API much easier to use. Keep your eye on https://github.com/AnalyticalGraphicsInc/cesium/pull/2315 , which I expect to be in the Feb. 1st release
