Hi all,
first of all, i want to thank you for the great job you guys did with Cesium.js, the API is awesome.
That being said, i did not find related topic to the one i am posting right now. So here it goes, what i am trying to do is to dynamically change the color of a polygon overtime. In order to do so, I developed some code that changes the value of rgb with an interval of time. Well the function is working, but it is not perfect. The code is also not perfect, i wrote it quickly as an example. As you can see if you paste the code below in Sandcastle, each time the color changes, there is a flashy spark over the polygons. My hypothesis is I think the flashy thing occurs because the entity is reloading the entire material. When you set the polygon material to plain (alpha channel to 255), you do not see the flashy spark when the color changes.
I am wondering, is there a better way to change the color of a polygon without having that flashy spark or reloading the entire material ?
Here is the code I used in Sandcastle,
var state= {};
function loadData(jsonFile, entitiesName) {
var statesDataSource = new Cesium.GeoJsonDataSource();
statesDataSource.load(jsonFile).then(function () {
viewer.dataSources.add(statesDataSource);
// Get entities from dataSources.
state.test = statesDataSource.entities;
//Set the camera to a US centered tilted view and switch back to moving in world coordinates.
viewer.camera.lookAt(Cesium.Cartesian3.fromDegrees(-98.0, 40.0), new Cesium.Cartesian3(0.0, -4790000.0, 3930000.0));
viewer.camera.lookAtTransform(Cesium.Matrix4.IDENTITY);
function fadeColor(entity) {
console.log("FADING COLOR....");
var r=255,g=0,b=0;
setInterval(function(){
if (r > 0 && b === 0) {
r--;
g++;
if (g > 0 && r === 0) {
g--;
b++;
if (b > 0 && g === 0) {
r++;
b--;
console.log("RGB: " + r + "," + g + "," + b);
entity.polygon.material.color.setValue(new Cesium.Color.fromBytes(r, g, b, 160));
},120);
function main() {
console.log("n_of_states: " + state.test.length);
// launch fading color on one entity.
fadeColor(state.test.values[0]);
loadData('../../SampleData/ne_10m_us_states.topojson', "test");
setTimeout(main, 5000);
Thanks in advance for your answer!
Best regards,
Fred
