Ideally I need the behaviors of a PolylineGlowMaterialProperty that has a taper and some amount of “glow” but I need the “glow” to not be “white”. I don’t see a way to set the “base” color of the line, only the “glow” - so ultimately it looks like a white line with a blue glow what I’d like is a blue line with a dark blue glow, with the ability to taper.
Also if possible, it would be useful if there was an arrowhead option as well.
Is there a way to achieve what I want.
var glowingLine = viewer.entities.add({
name : ‘Glowing blue line on the surface’,
polyline : {
positions : Cesium.Cartesian3.fromDegreesArray([-75, 37,
-125, 37]),
width : 10,
material : new Cesium.PolylineGlowMaterialProperty({
glowPower : 0.2,
taperPower : 0.5,
color : Cesium.Color.BLUE
var orangeOutlined = viewer.entities.add({
name : ‘Blue line with Navy outline at height and following the surface’,
polyline : {
positions : Cesium.Cartesian3.fromDegreesArrayHeights([-75, 39, 250000,
-125, 39, 250000]),
width : 10,
material : new Cesium.PolylineOutlineMaterialProperty({
color : Cesium.Color.BLUE,
outlineWidth : 2,
outlineColor : Cesium.Color.NAVYBLUE
var purpleArrow = viewer.entities.add({
name : ‘Blue straight arrow at height’,
polyline : {
positions : Cesium.Cartesian3.fromDegreesArrayHeights([-75, 43, 500000,
-125, 43, 500000]),
width : 10,
arcType : Cesium.ArcType.NONE,
material : new Cesium.PolylineArrowMaterialProperty(Cesium.Color.BLUE)
I need to render a polyline with an arrowhead that shows tapered decay.
1.60 and Chrome Version 76.0.3809.100 macOS Mojave (however Windows Chrome is also a target)
