Hello, I have a 3D model in ceisum ion but for some reason cesium ion leaves it flying, and I need this clampToGround, does anyone have an idea ???
Following up to your question on the old Google Groups forum here:
Sorry we have already tried to put manual as in the example but it has not worked at all!!
Here is the Sandcastle!
You can move the limit on the slide so you can move it further down, check the HTML tab in that Sandcastle.
Also, have you tried uploading your source model to Cesium ion? You should be able to export the OBJ model from Metashape and upload that.
