Coloring CESIUM_primitive_outline of b3dm buildings
i would like to ask if it is possible to define a declarative Style for coloring the outlines of 3D buildings (in this example Cesium Sandcastle)
thanks in advance,
Zhihang
@yaozhihang1986
Thank you for your question! I recommend checking out our Styling and Filtering 3D Tiles tutorial.
This should help you get started with defining styling constraints for a 3D Tileset. Reading our 3D Tile styling documentation would also be helpful. Here is a link: https://cesium.com/learn/cesiumjs/ref-doc/Cesium3DTileStyle.html
Let me know if you have any other questions or concerns!
-Sam
Thank Sam, I check the tutorial and documentation. But i didn’t find any information to answer my question. All examples there are for styling building surfaces, not the outlines. Does it means the styling on outlines is not possible?
@yaozhihang1986
I really appreciate that you took the time to look through the resources that I shared. Upon further investigation, I believe that you are correct.
Our API allows users to toggle building outlines on and off but we do not support styling the outlines. I wonder if creating a custom shader would be a potential workaround here.
-Sam
