Is it possible to eliminate the black bars on the top and bottom of the Columbus map mode by stretching the map vertically?
Thanks!
Thanks!
I’ve figured out a somewhat hacky solution to this, incase someone needs it:
If you set your viewer’s useDefaultRenderLoop to false, then you can make Cesium render into a fixed-sized viewer, then change the size to fill your window when it’s done. That involves setting up your own callback that runs periodically and putting this code in it:
const container = self.cesiumBase.viewer.container;
container.style.width = '2000px';
container.style.height = '1000px';
self.cesiumBase.viewer.render();
container.style.width = '100%';
container.style.height = '100%';
