I have a Sketchup model with a component with a transparent background. I see this is as it should be while working in Sketchup. When I Khronos export the model to a .glb, the model in Cesium is as expected except the background of that particular component is solid black.
I wish to improve the quality of the view.
Cesium 150, Window 10 and Fireforx, Chrome, or Edge.
It sounds like it’s outputting the texture using a JPEG instead of a PNG. Is there an option that lets you select what format of image to use when exporting?
Thanks, I looked at the Kronos site but could not find any option that applied. Would it be useful if I posted the .png I am using and sent you the link?
on the material. This is something the exporter should be doing for transparent materials, or giving you a way to choose which materials are transparent. I know the glTF exporter in Blender can do this:
