I have some oblique Photo data .osgb format, and i convert it to .gltf model through the collada2gltf.exe tools (https://github.com/KhronosGroup/glTF).
When i load the modes, the building became transparent,as show below.
From the looks of it, the converter thinks the meshes are transparent. It could be a few things. Did you recieve any warnings about an “unsupported opaque mode”? I have also seen this happen because of broken Collada exporters. To be able to give you a better answer I would need to see the source Collada model. Can you share that?
thank yuo for your replay, i find the answer at https://github.com/KhronosGroup/glTF/issues/342,i removed state 3042 from technique0 and technique1. and its works fine. but i dont known why. thanks again!
在 2016年6月16日星期四 UTC+8下午10:33:58,Tom Fili写道:
