Hi There,
I am new to Cesium and to java script/web development so excuse my ignorance. I have searched the group but can't find an answer.
I have exported Cesium ready tiles/app from context capture and I have successfully built the Cesium environment on my C drive and hosted the app locally. tiles display fine except for a height issue that I am yet to fix.
My issue is I have uploaded the project to my web domain and the tiles do not load/display. Pathing to my scene data json in the main.js is correct as far as I can tell?
index.html:-
<!DOCTYPE html>
<html lang="en">
<head>
<!-- Use correct character set. -->
<meta charset="utf-8">
<!-- Tell IE to use the latest, best version. -->
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<!-- Make the application on mobile take up the full browser screen and disable user scaling. -->
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
<title>404 Old Byron Bay Road_Without_Control_pts_CESIUM - Cesium 3D Tiles generated from Bentley ContextCapture</title>
<script src="Cesium/Cesium.js"></script>
<style>
@import url(Cesium/Widgets/widgets.css);
html, body, #cesiumContainer {
width: 100%;
height: 100%;
margin: 0;
padding: 0;
overflow: hidden;
</style>
</head>
<body>
<div id="cesiumContainer"></div>
<script src="main.js"></script>
</body>
</html>
main.js:-
// Get your own Bing Maps API key at https://www.bingmapsportal.com, prior to publishing your Cesium application:
Cesium.BingMapsApi.defaultKey = 'put your API key here';
// Construct the default list of terrain sources.
var terrainModels = Cesium.createDefaultTerrainProviderViewModels();
// Construct the viewer with just what we need for this base application
timeline:false,
animation:false,
vrButton:true,
sceneModePicker:false,
infoBox:true,
scene3DOnly:true,
terrainProviderViewModels: terrainModels,
selectedTerrainProviderViewModel: terrainModels[1] // Select STK high-res terrain
// No depth testing against the terrain to avoid z-fighting
viewer.scene.globe.depthTestAgainstTerrain = false;
// Add credit to Bentley
viewer.scene.frameState.creditDisplay.addDefaultCredit(new Cesium.Credit(‘Cesium 3D Tiles produced by Bentley ContextCapture’, ‘Resources/logoBentley.png’, ‘http://www.bentley.com/’));
// Bounding sphere
var boundingSphere = new Cesium.BoundingSphere(Cesium.Cartesian3.fromDegrees(153.5562881, -28.7147026, 49.49226305), 500.7051185);
// Override behavior of home button
viewer.homeButton.viewModel.command.beforeExecute.addEventListener(function(commandInfo) {
// Fly to custom position
viewer.camera.flyToBoundingSphere(boundingSphere);
// Tell the home button not to do anything
commandInfo.cancel = true;
// Set custom initial position
viewer.camera.flyToBoundingSphere(boundingSphere, {duration: 0});
* @bsimethod
// Functions to adapt screen space error and memory use to the device
var isMobile = {
Android: function() {
return navigator.userAgent.match(/Android/i);
BlackBerry: function() {
return navigator.userAgent.match(/BlackBerry/i);
iOS: function() {
return navigator.userAgent.match(/iPhone|iPad|iPod/i);
Opera: function() {
return navigator.userAgent.match(/Opera Mini/i);
Windows: function() {
return navigator.userAgent.match(/IEMobile/i);
any: function() {
return (isMobile.Android() || isMobile.BlackBerry() || isMobile.iOS() || isMobile.Opera() || isMobile.Windows());
// Add tileset. Do not forget to reduce the default screen space error to 1
var tileset = viewer.scene.primitives.add(new Cesium.Cesium3DTileset({
url: '../App404OldByronBayRoad/Scene/404_Old_Byron_Bay_Road_Without_Control_pts_CESIUM.json',
maximumScreenSpaceError : isMobile.any() ? 8 : 1, // Temporary workaround for low memory mobile devices - Increase maximum error to 8.
maximumNumberOfLoadedTiles : isMobile.any() ? 10 : 1000 // Temporary workaround for low memory mobile devices - Decrease (disable) tile cache.
Local build of Cesium is 1.45 but unsure of the version that Context Capture produced. Windows 7 enterprise, Chrome
Any help would be very much appreciated..
Roman
