I am wondering if there’s any way to convert a GeoJson polyline into a polyline volume.
Peter
//Example 2: Load lines with entity specific styling options.
Sandcastle.addToolbarButton(‘Lines with entity styling’, function() {
var promise = Cesium.GeoJsonDataSource.load(’…/…/SampleData/Noise_Walls_Lines_Interpolated_WGS84_Symbols.geojson’, {
clampToGround : false,
//extrudedHeight : 300.0,
width : 10.0,
cornerType: Cesium.CornerType.MITERED,
material : Cesium.Color.GREEN
console.log(‘adding data’);
promise.then(function(dataSource) {
//Get the array of entities
for (var i = 0; i < entities.length; i++)
//Set the height and the material of each polyline
var entity = entities[i];
//entity.polygon.width = 10;
if(entity.properties.Type == ‘Proposed Wall’) {
entity.polyline.material = Cesium.Color.YELLOW;
if(entity.properties.Type == ‘Not Proposed Wall’) {
entity.polyline.material = Cesium.Color.DEEPSKYBLUE;
if(entity.properties.Type == ‘Existing Wall - Reconstructed’) {
entity.polyline.material = Cesium.Color.DARKVIOLET;
if(entity.properties.Type == ‘Existing Wall - Remain Unchanged’) {
entity.polyline.material = Cesium.Color.DEEPPINK;
}).otherwise(function(error){
//Display any errrors encountered while loading.
window.alert(error);
//Reset the scene when switching demos.
Sandcastle.reset = function() {
viewer.dataSources.removeAll();
//Set the camera to a US centered tilted view and switch back to moving in world coordinates.
viewer.camera.lookAt(Cesium.Cartesian3.fromDegrees(-93.18813759, 45.13918514,), new Cesium.Cartesian3(0.0, 0.0, 10000.0));
viewer.camera.lookAtTransform(Cesium.Matrix4.IDENTITY);
Noise_Walls_Lines_Interpolated_WGS84_Symbols.geojson (1.64 MB)
