See my earlier post at https://groups.google.com/d/msg/cesium-dev/hjG83E7Pb7M/SVnmZcvvrosJ for an outline of what you’ll need to do. The short version is that you’ll need to convert the data from “shapefile” format into the appropriate CZML format offline on your computer, then write code to load it into Cesium using the CzmlDataSource class.
Now, the good news is that I finally got permission to actually contribute my shapefile-related CZML-Writer changes back. I made them almost two years ago, so they’re probably pretty out-of-date compared to the current build of CZML-Writer. I’ve just forked the CZML-Writer repo to https://github.com/markerikson/czml-writer , and will see if I can re-implement those changes sometime today.
Having said that, I am also attaching the country border and label files I generated myself. You can load them into Cesium using something along these lines:
var dataSourceCollection = new Cesium.DataSourceCollection();
var dataSourceDisplay = new Cesium.DataSourceDisplay({
scene : scene,
dataSourceCollection : dataSourceCollection
var czmlFiles = [“countryborders.czml”, “countrylabels.czml”];
czmlFiles.forEach(function(filename) {
var czmlDataSource = new Cesium.CzmlDataSource();
czmlDataSource.loadUrl(filename).then(function() {
dataSourceCollection.add(czmlDataSource);
dataSourceDisplay.update(new Cesium.JulianDate());
There’s probably a better way to do that, but that’s roughly the working code that’s in my application now.
Also, if I could give one general piece of advice: while I do applaud your willingness to ask questions, it looks like you’re doing a lot of copying and pasting code trying to make a couple things work, but without really understanding what’s really going on with the code. I would suggest that you take some time to do some reading and learning on both Javascript and Cesium. Go through some JS tutorials, read through the Cesium examples, look up the details of each line of code and try to understand exactly what each line does. One of the great things about trying to learn programming today is that all the info and tools you could ever possibly need are available for free online. One JS book I’ve seen recommended is http://eloquentjavascript.net/ , but there’s all kinds of other resources as well.
Please don’t take this as a brush-off or an attempt to make you stop asking questions, but rather as an encouragement to better learn the tools and concepts involved in using Cesium. It’s always easier to solve a problem when you have a good foundation to work with
Mark Erikson
CZMLCountryBordersAndLabels.zip (209 KB)
