I have a gltf model that works excellent, until I try to add a silhouetteSize to it. I receive this error:
[Cesium WebGL] Vertex shader compile log: ERROR: 0:21: 'a_normal' : undeclared identifier
ERROR: 0:21: 'normalize' : no matching overloaded function found
ERROR: 0:21: '=' : dimension mismatch
ERROR: 0:21: '=' : cannot convert from 'const mediump float' to 'highp 3-component vector of float'
[Cesium WebGL] Vertex shader translation failed.
undefined
RuntimeError: Vertex shader failed to compile. Compile log: ERROR: 0:21: 'a_normal' : undeclared identifier
Error
at new RuntimeError (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:3857:19)
at createAndLinkProgram (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:94535:23)
at initialize (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:94740:23)
at ShaderProgram._bind (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:94757:9)
at beginDraw (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:171285:23)
at Context.draw (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:171347:9)
at DrawCommand.execute (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:90539:17)
at executeCommand (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:236570:21)
at executeCommands (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:236934:17)
at executeCommandsInViewport (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:237347:9)
Note that the model passes this validator: http://github.khronos.org/glTF-Validator/
A SandCastle using the model that generates the error:
Adding a "halo" around the model, to help make it more visible.
Cesium 1.54 in the sandcastle, Cesium 1.48 locally. Chrome 72.0.3626.96 (Official Build) (64-bit) on Ubuntu 18.10.
